Fiesta Bonus - Zetec Turbo Update - Cooling update 31/7/13
Re: 2.0 ST170 Bonus Dirtbox Sleeper - Update 3/5 - Looking good
Postby jonyb4 on Thu May 05, 2011 1:33 pm
:aaah:
oh my thats a tight booking
Postby ~S1~ on Thu May 05, 2011 5:35 pm
Rhinopower :I've got soooo much to do today, its supposed to be at PE tomorrow for an hour on the rollers to be tweeked :o
You're gonna turn it into a 5-door? :o
~S1~
Hold On...
Hold On...
Postby Excursion on Thu May 05, 2011 5:41 pm
Postby jonyb4 on Thu May 05, 2011 5:50 pm
Postby Rhinopower on Thu May 05, 2011 6:10 pm
I've postponed my appointment with the rollers til Wednesday. Whilst the car could of been finished today, it would of meant rushing, and paying over the odds for some parts. The alt and pas pump are now all fitted, the belt needs to be 110cm long to do the job. Reservoir is bolted in, just need to decide how I'm running the coolant pipes
Rhinopower
Your car: Volvo FH330
Postby Rhinopower on Sat May 07, 2011 8:20 pm
Exhaust manifold is sorted, it needs to be fitted with socket cap bolts instead of nuts and studs. There simply isn't the clearance to have studs on there
Drive belt is on at last after 6 different belts. The correct belt for this setup is a 6pk1170
Power steering pipes are all connected. The top pipe aint pretty but i will get something better made up at a later date
Bottom rad hose is bodged on right now but im doing a group buy on getting a proper bottom hose made for connecting a blacktop water pump to a fiesta radiator, incorperating the use of the focus water rail instead of the fiesta item.
All thats left is steering column, and inlet manifold. Im picking up a standard escort manifold tomorrow to fit my injectors and TB to and hopefully start the engine tomorrow evening sometime!
Rhinopower
Postby jonyb4 on Sat May 07, 2011 8:27 pm
good stuff mate, if im honest id expect some bodges to happen, your short of time and its a difficult conversion to do im sure
keep it up :)
Postby ~nomad~ on Sat May 07, 2011 8:48 pm
lmfao at Brian doing a group buy :lol:
~nomad~
Your car: Breadvan
Postby Rhinopower on Sat May 07, 2011 8:50 pm
~nomad~ :lmfao at Brian doing a group buy :lol:
It ain't difficult, everyone calls up and pays for their own hose as they are making a batch for me once I've fitted the test hose
Rhinopower
Postby Rhinopower on Wed May 11, 2011 2:15 pm
Despite a monumental schoolboy error, its running. I've just got to take the column back out and fit the lower bush that i neglected to fit first time round to remove the play thats there at the moment.
Sounds nice tho, the smoke should clear up once its had a good run. Idle afr is 11 ish at the moment but leans up to a more respectable figure higher up the band.
Rhinopower
Re: 2.0 ST170 Bonus Dirtbox Sleeper - Update 11/5 Its alive!
Postby rs1800dom on Wed May 11, 2011 5:42 pm
awsome :) cant wait to see and hear this in the flesh, what a transformation from when you got it.
rebuilding new rs1800 engine with omex and jenvy throttle bodies. bring on the trumpets!!
rs1800dom
Your car: Mondeo ST tdci Estate/RS1800
Postby jonyb4 on Wed May 11, 2011 6:24 pm
thats a good feeling to hear it start up, been there :)
good job
Postby Spunkymonkey on Wed May 11, 2011 6:36 pm
Eargasm :D
Spunkymonkey
Your car: MK5 Fiesta 1.7 ZSR
Postby ~S1~ on Wed May 11, 2011 7:43 pm
Rhinopower :Despite a monumental schoolboy error, its running.
Which was?
~S1~
Hold On...
Hold On...
Postby ~nomad~ on Wed May 11, 2011 8:42 pm
Leaving the oil coolers rubber Gasket in place when he removed it so the oil filter leaked, fudgekin up the head rebuild and looking like a Japanese school girl. The last one was a few years back thou, quite fancied him then tbh.
~nomad~
Your car: Breadvan
Postby hb69 on Wed May 11, 2011 8:45 pm
Excellent news :aviator:
hb69
Your car: Fiesta 1.1 LX
Postby Smo on Wed May 11, 2011 11:02 pm
Sounds lovely... When's the remap now?
Smo
Postby jonyb4 on Thu May 12, 2011 12:53 am
~nomad~ :Leaving the oil coolers rubber Gasket in place when he removed it so the oil filter leaked, fudgekin up the head rebuild and looking like a Japanese school girl. The last one was a few years back thou, quite fancied him then tbh.
well atleast it was sorted before it developed further :)
Postby Rhinopower on Tue May 17, 2011 3:34 pm
Well after putting down 100 trouble free miles and no breakdowns i'm feeling happy with it. There is however play on the pinion on the rack so thats going to have to be changed. I've also downloaded a map for a rs1800 for megasquirt, but using Alpha-N instead of Map as the primary input, and has made a massive difference to the running, and afr is staying in limits the whole time, will still need adjusting but will have it on the dyno before hand to see what its making at the moment.
A few pictures to wet your appetite! It shows all the routing of the new pas pipes, and the mods to fit the alt & pump
Rhinopower
Re: 2.0 ST170 Bonus Dirtbox Sleeper - Update 17/5 first 100 mile
Postby jonyb4 on Tue May 17, 2011 3:58 pm
looks good, tidy and neat
still running the nitrous then :lol:
what inlet is it using? looks like a standard focus or escort item
i thought the ST170 had a revised inlet that was key to its power :-?
Postby Rhinopower on Tue May 17, 2011 4:03 pm
The inlet is an escort item. The focus inlet has variable runner control but not possible to fit while retaining the master cylinder and servo. The vvt and lairy inlet cam contribute towards the extra power it makes too.
The nitrous is staying of course, I'm aiming to make 200bhp with gas
Rhinopower
Postby jonyb4 on Tue May 17, 2011 5:44 pm
good figure
why not sue the 1.8/2.0 focus inlet, its a better item than the escorts
i have one sitting in the garage i was going to modify to fit, just needs some blanking for the breathers, and the TB plate altering a tad
Postby Rhinopower on Tue May 17, 2011 5:57 pm
I considered the focus but I might only be using it as a stop gap for throttle bodies
Rhinopower
Postby Excursion on Tue May 17, 2011 6:58 pm
This is completely wonderful.
Postby ~nomad~ on Tue May 17, 2011 7:59 pm
Course it is.
~nomad~
Your car: Breadvan
Postby Tweek on Tue May 17, 2011 8:00 pm
Beautiful.
Your car: VW Golf GTD
Postby jonyb4 on Tue May 17, 2011 8:40 pm
just realised that air filter has a hole in the pipe :(
Postby Fraggle on Tue May 17, 2011 9:22 pm
:bonkers: Looking good..A true sleeper... :Q
Fraggle
Postby knuckles on Tue May 17, 2011 9:34 pm
jonyb4 :just realised that air filter has a hole in the pipe :(
extra suction :wink: :lol:
knuckles
Your car: Fiesta Rs turbo
Postby ~nomad~ on Tue May 17, 2011 10:57 pm
oh noes.
~nomad~
Your car: Breadvan
Postby knuckles on Tue May 17, 2011 11:36 pm
its a good job ryan still has my mig welder.
he can weld up that hole in a flash :wink:
knuckles
Postby jayrs on Wed May 18, 2011 10:08 am
knuckles :its a good job ryan still has my mig welder.
not unless the mig is set for alloy welding, and yours aint :P :lol:
plug it with a nut and bolt
Postby pjdj1989 on Wed May 18, 2011 2:15 pm
Looks factory fit.. well sort of!
pjdj1989
Postby Rhinopower on Wed May 25, 2011 9:39 pm
Im going to be a sheep and fit a mondeo servo and master cylinder to improve the brakes, my friend knuckes is coming over to help me do it. :lol:
Also on the fitting list is:
Zetec S rear beam, with polybushes
PAS lower arms
Table switching switch for the ecu to allow a retarded map
New vacuum hose for map sensor
Plan is to get it tidied up ready for bedford on 17th June, its also back on the rollers on 2nd June!
Rhinopower
Postby knuckles on Wed May 25, 2011 11:46 pm
Rhinopower :Im going to be a sheep and fit a mondeo servo and master cylinder to improve the brakes, my friend knuckes is coming over to help me do it. :lol:
BAAAAAHHH !!!!! LOL :lol:
what have i begun :oooh:
knuckles
