Fiesta Bonus - Zetec Turbo Update - Cooling update 31/7/13
Re: 1.8 zetec Bonus Dirtbox Sleeper - ITB's 5/3
- Rhinopower
- Your car: Volvo FH330
- Turboboy67
- Your car: 911GT3 RS
They look huge mate, what diameter?
45mm, dont look huge in the flesh tbh.
If you think that seat is dirty Shaun you should see the drivers one. That he has pooed himself on twice.
- ~nomad~
- Your car: Breadvan
45mm...but earlier you wanted to sacrifice top end for low down torque?
Assuming a well tuned exhaust and inlet, 45mm will support approx 65bhp per cylinder on an N/A engine. You will loose a lot of low to mid range response with something so large on your engine.
I will be interested to see how it performs as its a option for mine. I remarked that they looked small when I saw them lol
- ~nomad~
~nomad~ :I will be interested to see how it performs as its a option for mine. I remarked that they looked small when I saw them lol
lol. The Pulsar inlet would be a better option for your spec mate. Mine was £35 from eBay.
but seems to be lots of work to get to fit?
- ~nomad~
They do look big, what are they off?
Maybe using a 105 cam coupled with these will give a balanced torque curve
jonyb4 :They do look big, what are they off?
That would defeat the object even more!
- Smo
~nomad~ :but seems to be lots of work to get to fit?
If I get mine done soon you boys can borrow it for a bit to see what you think.
Sounds good mark. Will see how easy they fit, the linkage on these are brilliant and allow you to space them closer or further apart by approx 7mm in total.
Jony these came off a car, I will keep my eyes out for some piper fast road cams
Smo and dave I love you both
Carbonboy, where's my teabagging?
- Rhinopower
I wouldn't lend anything to these two, could end up anywhere.
Rhinopower :Sounds good mark. Will see how easy they fit, the linkage on these are brilliant and allow you to space them closer or further apart by approx 7mm in total.
Yeah that would be handy!
Max M4X WW :I wouldn't lend anything to these two, could end up anywhere.
I have sold your wheels, deal with it.
Marky Mark and Funky bunch - sounds cheeky, I am intrigued by them, but also by this.
Jony - as Brian says, they are off a car, i can confirm this. Thanks for the advice, i will be sure to file it in my pointless nonsense box.
- ~nomad~
~nomad~ :Thanks for the advice, i will be sure to file it in my pointless nonsense box.
- RS rob
Small pictureless update
I've ordered a new flange for the itb's to get the spacing right, the original was too narrow. The bodies themselves are actually 42mm too!
I also picked up a complete 2.0 silvertop for £90, the head is to be sold on and my existing 1.8 head overhauled, new stem seals etc and fitted onto the new bottom end. Im going to start the stripdown of both engines tomorrow. I'm also looking at making a new engine loom to suit the new layout and braid it to look nice.
Also in the interest of keeping the engine build as pikey and cheep as possible I'm going to reuse my old timing belt, pullys and waterpump
- Rhinopower
oo nice, very cheap
are the 1.8 and 2.0 heads more or less the same then?
1.8 head is higher compression on a 2.0 engine, the combustion chamber is 5cc smaller
- Rhinopower
cann you not use the 2.0 head on a 1.8 to lower the compression when turboing it?
or am i off the track?
jonyb4 :cann you not use the 2.0 head on a 1.8 to lower the compression when turboing it?
It's not ideal because the bore size is larger.
- Smo
itb's, looking forward to seeing them
am really loving this car and its progress.
rebuilding new rs1800 engine with omex and jenvy throttle bodies. bring on the trumpets!!
- rs1800dom
- Your car: Mondeo ST tdci Estate/RS1800
Small update.
I had purchased a 2.0 zetec but days later an ST170 engine came available for a price i couldn't refuse so i'm going to slap this in instead.
Im going to fit the standard st170 side engine mount as i've destroyed two standard zetec mounts. The engine should move less given that its supported on the side, rather than the back of the engine.
I'm still keeping the itb's, i've had a new flange made spacing the ports a bit further apart making them an even better fit. I've got a new megasquirt loom coming which will be braided and terminated in a couple of weeks, and a few changes need making internally so I can have some control of the vvt.
More pictures to come!
- Rhinopower
- jonboisescort
Car: 1994 Ford Fiesta
Re: 2.0 ST170 Bonus Dirtbox Sleeper - Update 20/3
jonboisescort ::Q
great stuff mate
is it going to be at fitp ??
Absolutely!
- Rhinopower
Superb mate. If there is room in the budget, get a set of decent cams in there. You'll hit a brick wall with the standard cams.
Sadly not mark, Any suggestions what to go for?
- Rhinopower
Something from here: http://focus.c-f-m.com/freeshippingcatc ... st170.aspx
Great to see another ST170 MK3 Fiesta in the making - can't wait to see it at FITP
- jimmyesh
- Your car: Yes
Everytime i look this car is getting better
It should be a little rocket with the 170 lump in!
- Ratspeed
Those are some expensive cams! I had briefly looked at the newman cams but would still be looking at £350.
And thanks for your help so far Jimmy & Mark!
Im also going to fit power steering, it could do with being a bit lighter, and when strapped in with the harnesses manoeuvring the car can be difficult
- Rhinopower
- Tweek
- Your car: VW Golf GTD
I really really hope so! I've not given myself much of a deadline to get it fitted and mapped by but im hoping for bags for noise and power!
- Rhinopower
