do i need spacers to fit 15 ford alloys?
16 posts • Page 1 of 1
i have a frst and want to fit some escort gti alloys can any one tell me if these will rub on the suspension 195/50/15 tyres if so what spacers do i need.
- simon turbo
- Your car: fiesta rst, ka,fiesta o8
Re: do i need spacers to fit 15 ford alloys?
I dont believe they need spacers, at least they didn't when I had them on my MK5... I'm sure someone will be along to correct me shortly though lol
- dontpannic
shouldnt do, although you should really use 195/45/15 tyres
What model fez?
- bas saph
bas saph wrote:What model fez?
its a frst fella, says in the first post
jayrs wrote:bas saph wrote:What model fez?
doh so it does
- bas saph
, easy missed when skim reading mate, ive done it
i had to use spacers on the back for the 15 gti alloys to hold them out from the shok
- mikeymikeyp
thanks for that 5mm spacers should be ok then?
- simon turbo
simon turbo wrote:thanks for that 5mm spacers should be ok then?
im not sure but i think mine might be bigger !!!
- mikeymikeyp
i put sixteen inch mondeo 2.0l wheels on my mk3 rs1800 needed 3mm spacers fine now running 195/45/16
RS1800 Done and dusted
- Dwayneology
- Your car: Yamaha YZF R1, RS1800
do u know the et of your alloys.
mk1 focus alloy et52.5 and i was try to put them on my fiesta rs and the need alot i had 15mm spacers on and the still needanother 10 at least altho they r 195/55/r15 (that is for the back)
on the front they need about 10mm spacers
i have mk 6 fiesta alloys the i will be using once car is finish and they are et47.5 so i will need 5mm less when it comes to spacers but will maybe still use 185 tryes to keep clear of the spax strut
might be different because im using rs2000 discs on the back
- scottrennie14
i put a set on my 1.1 and needed 10mm spacers on the front as they rubbed on full lock still do a tiny bit if moving quickly while on full lock tyres are 195 50 15
- jakerowles
- Your car: pulse adrenaline 125 / klx650
i have a set of 15" rs7's with an et40 with no rubbing on the back, but slight rubbing on full lock on front
- AW3K
jakerowles wrote:i put a set on my 1.1 and needed 10mm spacers on the front as they rubbed on full lock still do a tiny bit if moving quickly while on full lock tyres are 195 50 15
I would change the tires
- fiestajames
- Your car: xr2i
fiestajames wrote:jakerowles wrote:i put a set on my 1.1 and needed 10mm spacers on the front as they rubbed on full lock still do a tiny bit if moving quickly while on full lock tyres are 195 50 15
I baught the wheels and allready had new tires on so not changing them ive took the spacers off now as they didnt look safe i rareley use full lock anyway so the rubbing dosent really matter
- jakerowles
