brakes
4 posts • Page 1 of 1
brakes
whats the biggest sized brakes you can fit under 15s???
old fords never die...............they just get faster!!!!!
- white diamond
Re: brakes
278's from a Mondeo ST24 confirmed by me (on my car). That's decentish clearance with no adjustments by angle grinder. I think i've read of 300's with said adjustments.
- DanFraser
Re: brakes
300mm if you use ST170 disc's and modded Mk3 Mondeo Calipars and Carriers, Modded I mean by shaveing of some metal from the Calipar and Carriers. A lot a Mk5 Fiesta Zetec-S Owners do this, personally I would use the 278mm Mk2 Mondeo ST24\Escort Cossise setup as advise above with some decent make disc's & pad's.
I've got 278mm ST24 setup on my mk5 Fiesta ZS, and 2wd 4 pot Cossie calipars with 285mm disc on my Mk3 Fiesta Si track car. The 285mm disc need a 10mm spacer between them and the Fiesta Hub to fit, with longer stud bolts.
53 Reg Focus RS - No.2169
13 Reg Midnight Sky Fiesta Zetec-S 1.0T
M Reg 5 dr Java Blue Fiesta Track Car (In Progress)
- philip_d
- Your car: Ford Focus RS Mk1
Re: brakes
i sold my old team dynamics pro race 2s 15" to a guy with an st170 and they fit over hes brakes, so some 15s will fit over 300mm setup with no modification
- stuff n that
