Zetec Exhaust manifold
14 posts • Page 1 of 1
The chromed pipes that come out of the exhaust manifold have snapped on the T section. Can these be replaced or do i need another manifold?
Any help would be great
- jeek
sounds like the pulse air system to me. not too sure if it'll run without it.
- jdfiesta
- Your car: V70 T5
Are you talking about the pulse-air system that has the 4 pipes that go into the manifold? If you can get to take them off, you can get blanking plugs like I have done. I cant remember the Finis code for them but i'll try and find it for you.
- krsi
Got these off an old thread so i hope there correct
Blanking plugs - FINIS 6732263
Copper Washers - FINIS 1008597
Hope this helps
Hope this helps
- krsi
Also RogerP@Edwardsford.co.uk He should be able to get them for you, Get him to check them first, but he's usually helps me out a lot, he's a good bloke and cheaper than most.
- krsi
- krsi
Give that roger an email at RogerP@Edwardsford.co.uk , he's from fords, say you got he's address of me and give him the finis codes.
- krsi
krsi wrote:It can run as just as well without it, as its job it only to inject air into the exhaust system to get the cat up to operating temperatures quicker.
this is wrong mate.
the motor pulls air from the exhaust manifold throught the filter then puts it into the inlet on cold start up.
this was for emmission purposes but its not needed for the mot.
- 16vzetec.com
Re: Zetec Exhaust manifold
currently looking at doing this myself , what would happen if i fitted a aftermarket manifold , do i do away with the pulsair system ?
- jordan2litre
- Your car: Fiesta mk3 SI 2.0L
Car: 1995 Ford 2.0 zetec
I have a non egr manifold for sale if anyone is interested not just a bunged off one. £15 posted
accralite pistons,steel rods,stg3 head,stg3 T3,kent cam,cts gearbox,Gotech MFI PRO X,VXR Injectors.
- matty872
- Your car: E46 M3 + st170'd Escort GTI
jordan2litre wrote:currently looking at doing this myself , what would happen if i fitted a aftermarket manifold , do i do away with the pulsair system ?
Yep.
- - Danny Boy -
- Your car: Fiesta Si 2.0
Thursday, 7th October 2021 23:21
