Will strut braces make THAT much difference?
Postby Big_Phil on Sat Oct 03, 2009 7:34 pm
Considering buying/making a front and rear strut brace for the fiesta.
Just wondered what people thought of them?
Is one better than the other? Worth having both?
Can you actually feel the difference?
Cheers.
Big_Phil
Re: Will strut braces make THAT much difference?
Postby fiend on Sun Oct 04, 2009 12:57 am
I put a rear one on my XR2i that has standard suspension, it made a HUGE difference..the backend was alot stiffer/solid.
fiend
Postby JamieFRST on Sun Oct 04, 2009 1:06 pm
I noticed a difference after fitting a front and rear one, seems to have less roll when going into round abouts. It helps by maintaining suspension geometry.
JamieFRST
Keep It Tidy
Keep It Tidy
Postby Big_Phil on Sun Oct 04, 2009 2:13 pm
Do you think i'd notice the difference as i'm already on coilovers?
Big_Phil
Postby JamieFRST on Sun Oct 04, 2009 8:07 pm
I'm only running Koni adjustables so couldn't really say, at the end of the day you have decent suspension, so a strut brace can only compliment that further. They aren't really expensive so worth a go, can always put it on ebay if your not happy with it.
JamieFRST
Keep It Tidy
Keep It Tidy
Postby Minstral on Mon Oct 05, 2009 8:58 am
im running coilovers at the moment, and ive polybushed both arb's, and hoping to fit a second rear arb with both strut bracesso should handle even better after that :Q
Minstral
Your car: *
Postby Norbertas on Sun Oct 11, 2009 1:29 pm
I'd like to ask about OPM front strut brace. It has adjustment of length. Just put it in, few hours ago and i wonder what to do next:
1. - tighten the adjusting bolt, to drag both shocks inside |O--> <--O|
2. - loosen the bolt to push shocks from each other |O <-- --> O|
Those graphics are top view of car bay.
Hope someone will understand it.
Norbertas
Postby Fezzy Turbo on Mon Oct 12, 2009 2:56 pm
If your fitting strut braces, please remember to tell your insurance. They will know if you have fitted them because if you do have a bash, damage will transfer over to the other side as well. I did have to pay a little but more for having strut braces.
2009 FRS2 : 377bhp ATW / 395lb/ft :)
1990 FRST : Sold.
Fezzy Turbo
Tartan Turbo Terror
Tartan Turbo Terror
Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
Postby Norbertas on Tue Oct 13, 2009 9:30 am
As i understand from other forums, it is better to mount strut brace when the car is lifted, to have no self weight tention on shocks. After mounting it, to tighten slightly, adjusting bolt, so both sides have minimum tention to each other. And only then put the car back on ground. Is that correct?
Norbertas
Postby Fezzy Turbo on Wed Oct 14, 2009 11:28 am
Norbertas :As i understand from other forums, it is better to mount strut brace when the car is lifted, to have no self weight tention on shocks. After mounting it, to tighten slightly, adjusting bolt, so both sides have minimum tention to each other. And only then put the car back on ground. Is that correct?
No idea, i just fitted mine when it was on the ground with no problems. They do work very well :)
1990 FRST : Sold.
Fezzy Turbo
Tartan Turbo Terror
Tartan Turbo Terror
Postby sparkyt on Sat Oct 17, 2009 6:59 pm
They worked a wonder on mine, makes round abouts very fun, you can then slide it with confidence. fitted mine on ground and just tensioned up front one very slightly as i think too much tension will alter the geometry which without the special gear to set it up could make tyres wear incorrectly. Also could be a bit dangerous.
sparkyt
Postby TANGO. on Wed Oct 21, 2009 1:49 am
just a thought about my rear omp brace, I know it should be fitted the correct way with the sticker reading the right way, but would it make any difference in fitting it the other way around so that the cup bit wraps around the suspension turret, I just think it looks better that way!!!!
TANGO.
Postby Excursion on Thu Oct 29, 2009 1:11 pm
That is correct.
A similar principle applies to lower arms; the 2 inner nuts/bolts should only be tightened when the car is back on the ground.
Postby Excursion on Thu Oct 29, 2009 1:13 pm
vauxhallscum :just a thought about my rear omp brace, I know it should be fitted the correct way with the sticker reading the right way, but would it make any difference in fitting it the other way around so that the cup bit wraps around the suspension turret, I just think it looks better that way!!!!
Yes, that's how I fitted mine. I had to 'massage' the turrets with a lump hammer to get sufficient clearance.
The rear strut brace is useless when fited in the way it was desgned to.
A Mk3 rear strut brace should bridge the shoulder of the turret. I see some welded on the flat panel inside the boot, and some like the OMP which bridge the bolts - both desings are useless.
Postby scottybo on Wed Aug 11, 2010 6:54 pm
not to mention they look cool
scottybo
Your car: mk3 frescrati
