fiesta st170 turbo
Re: fiesta st170 turbo
Postby rsturbonutter on Sat Jun 23, 2012 5:45 pm
Looking very nice fella. Don't look like you got much room for a bigger servo though
rsturbonutter
Your car: Fiesta RS turbo
Sponsored Links
(not a real person)
Postby RS rob on Sat Jun 23, 2012 5:51 pm
top effort here mate
RS rob
Postby crazycage on Sat Jun 30, 2012 4:01 pm
small update,
with my rad being a tad on the small side i have gone for a turbo/wastegate pre rad to help keep things under control :)
it started life as a s2 escort turbo pre rad but i have cut off the fittings and brackets and welded my own ones on :)
crazycage
Postby FRSJON on Sat Jun 30, 2012 5:47 pm
love it ! :Q
FRSJON
Postby fiestarsturboblack on Sun Jul 01, 2012 4:31 pm
looks gd mate :)
fiestarsturboblack
Your car: fiesta rs turbo
Postby crazycage on Mon Jul 02, 2012 8:38 pm
made a start on the breather tank, will weld a baffle into it then the rear and bottom with a drain too. :D
crazycage
Postby - Danny Boy - on Mon Jul 02, 2012 8:48 pm
Awesome work! Rather handy with the welder aren't you :D
- Danny Boy -
Your car: Fiesta Si 2.0
Postby crazycage on Mon Jul 02, 2012 8:51 pm
- Danny Boy - wrote:Awesome work! Rather handy with the welder aren't you :D
should be , its what i do for a living :o
crazycage
Postby creator on Mon Jul 02, 2012 10:34 pm
Nice work as usual mate looks ace :aviator:
You just need to try and find enough time on your own car to get it finished now mate :)
Also just noticed have you made your own v band exhaust housing on your turbo mate? :wink: if so how much to do it to mine :lol:
creator
Postby crazycage on Tue Jul 03, 2012 6:41 pm
creator wrote:Nice work as usual mate looks ace :aviator:
cheers mate, i bought the v-band exhaust housing when i i got the turbo years ago mate but i could make one , what turbo do you have?
crazycage
Postby crazycage on Tue Jul 03, 2012 6:45 pm
finished the breather tank :D also bought a new turbosmart fuel presure reg and a load more fittings lol. also got my one way valve :)
crazycage
Postby - Danny Boy - on Tue Jul 03, 2012 7:40 pm
I never knew you did it for a living. Top stuff :aviator:
- Danny Boy -
Postby crazycage on Mon Jul 30, 2012 8:47 pm
small update , fitted some of the new fittings , piped in the water feed and return for both turbo and external wastegate and plumbed them into the pre rad and and also plumbed the pre rad into the main rad.
got the one way valve for the dry sump and piped that into the breather tank.
and fitted the new fuel pressure reg :D :D
crazycage
Postby fiestarsturboblack on Mon Jul 30, 2012 9:09 pm
lookin good as always gary :)
fiestarsturboblack
Postby 2105adam on Mon Jul 30, 2012 9:30 pm
Looking great. What ECU you going to run as I see the coil on plug conversion?
Sent from my HTC Desire S using Tapatalk 2
2105adam
Your car: Ford Fiesta 2.0 Zetec turbo
Postby Excursion on Mon Jul 30, 2012 9:48 pm
Good work. It's looking very busy in there already.
Postby crazycage on Mon Jul 30, 2012 10:07 pm
2105adam wrote:Looking great. What ECU you going to run as I see the coil on plug conversion?
i run ms2 :)
crazycage
Postby crazycage on Mon Jul 30, 2012 10:10 pm
Excursion wrote:Good work. It's looking very busy in there already.
trying to keep it as neat as i can but its not working :lol:
crazycage
Postby jonyb4 on Mon Jul 30, 2012 10:28 pm
jesus this is one complicated engine bay, looks bloody brilliant though!!
them 888's have reached theyre end thou :P
Postby crazycage on Tue Jul 31, 2012 8:17 pm
right thats about all i can do now with the mock engine/box so it will all be pulled out at the weekend so i can strip down and paint the bay. (black) :)
crazycage
Postby FRSJON on Tue Jul 31, 2012 9:14 pm
looks awesome as usual gary !.. now we have the same fuel reg i could do with picking your brains :)..i know you havent had it running yet but what sort of pressure would you see at idle? my injectors are 475cc at 3 bar.. would i see 3 bar at idle ?cheers
FRSJON
Postby jayrs on Tue Jul 31, 2012 10:44 pm
that is looking awesome :Q
Your car: FRST, XR2, ST170
Postby jonyb4 on Wed Aug 01, 2012 3:39 am
surely sillicon or rubber hoses would have been cheaper? :o
Postby luca on Wed Aug 01, 2012 1:19 pm
Looking great Gary :Q :Q
luca
Postby TIL13R on Wed Aug 01, 2012 5:48 pm
Really looking good... cant wait to see it all painted and fibally all finshed...
TIL13R
Postby crazycage on Wed Aug 01, 2012 7:44 pm
FRSJON wrote:looks awesome as usual gary !.. now we have the same fuel reg i could do with picking your brains :)..i know you havent had it running yet but what sort of pressure would you see at idle? my injectors are 475cc at 3 bar.. would i see 3 bar at idle ?cheers
you need to pull the vacuum pipe off the reg and block it so you dont have a air leak then start the engine and adjust the reg , 3 bar at idle is fine :)
crazycage
Postby FRSJON on Wed Aug 01, 2012 8:10 pm
will do ,cheers :)
FRSJON
Postby FRSJON on Mon Aug 06, 2012 9:58 pm
cheers gary,did fuel pressure today and was 3 bar with vac pipe on and 3.5 bar with it off so turned it down ..thanks again :Q
FRSJON
Postby crazycage on Fri Aug 10, 2012 8:03 pm
been building these :D
crazycage
Postby FRSJON on Fri Aug 10, 2012 8:31 pm
great work gary :Q
FRSJON
Postby jonyb4 on Fri Aug 10, 2012 10:03 pm
oh my! that must have a massive engine bay!
great work
Postby crazycage on Sat Aug 11, 2012 4:29 pm
few more of them all tacked up ready for welding :D
crazycage
Postby Excursion on Sat Aug 11, 2012 6:54 pm
Awesome :D
Postby HCS PIMP on Sat Aug 11, 2012 7:35 pm
that an r32 lump ??? golf bI TURBO
HCS PIMP
Postby crazycage on Sat Aug 11, 2012 8:37 pm
HCS PIMP wrote:that an r32 lump ??? golf bI TURBO
:lol: no next guess please :)
crazycage
23:21, 29th April 2013 web
