HO inlet on ZT
HO inlet on ZT
Postby simps on Sat Jan 15, 2011 1:40 pm
where would i take the vac pipe for the map sensor could i put it into my crossover or does it have to be behind the throttle body?
simps
Sponsored Links
(not a real person)
Re: HO inlet on ZT
Postby jonyb4 on Wed Feb 23, 2011 1:35 am
you can use the crossover yes, a standard fiesta/escort RS turbo crossover is popular on this conversion as it has the take off already there, and is strong enough for the boost
or you can drill and tap a take off on the back of the HO inlet, but that will be perminant
Re: HO inlet on ZT
Postby Smo on Wed Mar 02, 2011 12:13 am
I just use one of the two take-offs that's already on the back of the HO inlet. No need to mess about with anything else :)
I'm pretty sure you wouldn't want it before the throttle or else you won't really be getting a good vacuum reading when the throttle is closed, if at all!
Smo
Re: HO inlet on ZT
Postby simps on Fri Mar 04, 2011 3:53 pm
ok kool i know the ones ure on about on the underside at the back of the inlet
simps
23:21, 29th April 2013 web
