slipper wrote:a big bomag? not a clue how get ripples out, but tigar seal is best to reatach them.
hb69 wrote:Clark speaks sense
slipper wrote:why would you want to take them back off???
tigar seal all the way for sticking out to anything.
knuckles wrote:slipper wrote:why would you want to take them back off???
Well you may want to remove them for styling reasons or to repaint panels
so it makes sense to use the correct double sided foam tape. Which is still a nightmare to get off the bodywork.
you wont get tiger seal off paint work without a sanding disc on a drill which will ruin any paintwork
Gaz_rst wrote:Thanks for the advice any way how can i remove the ripples and the old glue and double sided tape from the stripes
rs-tom wrote:one day i had a arguement with the missus i got ma bent green strips
rob pace wrote:pain in the arse to get straight if there 2nd hand! i tried a lot of ways! in the end i managed to find brand new strips about 6 years ago! even got some spare door ones in the loft just incase!
slipper wrote:get the tiger seal on em!!! f**k nobbin around with sticky foam and s**t, may as well use blue tac. i used it on a previous car no problems.
slipper wrote:ok, you boys obviously like touching cocks withs each other, and too scared to use some decent bonding material. no wonder most of your fezzes are falling apart
jayrs wrote:and for your info, my fez isnt falling apart, but if it was i will be sure to get some no nails to keep it stuck together
jayrs wrote:slipper wrote:ok, you boys obviously like touching cocks withs each other, and too scared to use some decent bonding material. no wonder most of your fezzes are falling apart
wtf...??
are you on something?, i mean come on, honestly, who the fcuk uses no nails to stick plastic side strips on..... scared has nothing to do with it, its common sense, i mean, you wouldnt use a JCB do do some weeding, why use "decent bonding material" when its clearly not needed and total over kill.....
no one said it wont stick them on, we just all agree its over kill, not needed, and clearly not the best stuff, and way of doing it, and you dont agree with us, which is fine, no need to spit the dummy out
RS Joe wrote:Just come across this thread pimsle![]()
fookin hilarious
