i will explain how to do the fiesta rs turbo cvh sump gasket that will not start pissing out oil the moment you start driving. i know a lot of people think this is a nightmare job when it starts to leak once you have put everything back together
tools required-
18mm socket
17mm socket
13mm socket
10mm socket
8mm socket
13mm spanner
18x 10mm nuts
ratchet
jack
superglue and brush
high temperature silicone 900 degrees stuff
jack the car up from the side to remove the exhaust system (middle section + backbox if you wish to
now place the gasket onto the sump and use the 18x bolts you took the sump off with and your 18mm nuts to hold the gasket in its place
with your superglue and brush apply small amounts of glue to the sump edge and stick the gasket on carefully. pay more attention to the side of the sump where the half moons are and make sure its stuck down fully, but do not go stupid with the glue ok?
now you can see how good the gasket fits in place.
with your high temp silicone apply a small amount where the half moons are just to be sure, you may not need to do this though
now the above is all done and dusted, remove the nuts and go to trial fit your sump, only do the nuts up hand tight, the correct torque setting for these is 8nm. now remove the nuts again and take the sump off and inspect the gasket to see if any of it has slipped off. if its all ok, go and refit your sump then all the relevent parts you took off to get to the sump. once its all back together fire your car up and leave on idle for a while, then take her for a very very short drive and check the gasket to see if its all ok
this way worked extremely well for me, some of you may not agree with using superglue, but i only used very small amounts to hold the gasket in place. it may not be the pefect guide but it helps, please tell me if i have missed anything out
