[Guide] Fitting A Rear Courtesy Light
Postby AW3K on Sun Sep 18, 2005 12:03 pm
How about this for a strange guide!
Have you ever had a passenger in the back that wants to look for something in a bag or they dropped something on the floor at night? If you have you will know how annoying and illegal it is to have the interior light on at the front whilst driving.
In this guide I show you how to install a rear courtesy light and respective wiring
I stumbled across this by accident while I was stripping project £40. so excuse the mess in the photos.
If you have the pillar trim covers in your car, these will need to be loosened or removed first, simply a number of screws holding them in position. Then, you need to drop the headlining; this is rather straightforward, pop out the little plastic clip rivets that are along the back and down the sides of the lining.
Remove the coat hooks and grab handles, also remove the sun visors and the front interior light. All of these are held in with screws under the plastic tabs.
The last things that are holding the lining up are the door and boot rubber seals and some very weak glue.
As the headlining comes free, make sure that you support it, while you check to see if the hole for the light is there, it should look like this and should be there on all modals. You will also notice that on the back of the headlining there is a recessed area to enable the lining to be cut.
If the hole is there, measure from the rear edge of the lining to the middle of the hole and hold the lining back up to the metal and stick a knife into it and cut away, bit by bit until you get to the edges, I know it looks messy but it will be covered by the light.
Now its time to make a loom up, yes I know, I like making looms!
The neatest way to do this is to cut the connectors and a length of front wiring loom from a scrap car and extend it.
The total length of the loom from connector to connector is 267cm, which is long enough to reach from the middle of the back of the car, through the roof and out to the middle of the car to the front courtesy light.
Make sure that you wrap it all up well with a few layers of insulation tape.
Start at the cutout in the rear and feed the wiring to the right behind the panel until you get to the c pillar, at this point you need to get the wire out through one of the circular holes and then feed it back into the roof cavity along the passenger side.
When you reach the “A” pillar or windscreen you will meet the Arial wire, follow this wire to the courtesy light aperture and pull the wires out of it.
Its time to make a connection! Crimp a piggyback connector to each of the wires making sure that you use insulator sleeves to protect against short circuits and the unit from being earthed.
Connect the piggyback connector to the lamp unit and then the original wiring to the piggyback, do this for all the wires and wrap insulation tape around any part that remains exposed.
Refit the headlining, this is removal, reversed, refit all the trims and rubber seals.
With the rear courtesy light wiring hanging from the roof it is time to connect a light to it.
The light unit is the same as the one used in the front that has the integrated on-off-door, switch.
Push the connectors onto the lamp, the red single wire connects to the side of the bulb and the two way plug connect to the base of the bulb, it doesn’t matter which way this is as both will work.
Push the light home into the roof lining and it will click.
Flick the switch to on and the light should come on, flick it back to off and it will go off. Then flick it to door switch position and it should be off until you open a door, and then go off as you close it.
There you have it, simple guide to shed some light on the backseat drivers in all of us.
Hope it was of some help
Guide written by AW3K Andrew Whiteman 16th September 2005
Comments suggestions etc welcome as always
AW3K
Sponsored Links
(not a real person)
Postby Sphinx on Sun Sep 18, 2005 12:07 pm
Fair play mate!! Little quality touches like that impress me :D
Good guide as well, but i have a new found hatred for wires so i probably wont do it :lol:
Postby AW3K on Sun Sep 18, 2005 12:09 pm
sphinx wrote:Fair play mate!! Little quality touches like that impress me :D
cheers mate :)
the hardest part is taking the lining down, a right pain.
why you got a hatres for wires then?
AW3K
Postby Sphinx on Sun Sep 18, 2005 12:11 pm
I have a Peugeot......french car.......wireing......NOT a good mix, and its had many gremlins that have pissed me off :x
Re: [Guide] Fitting A Rear Courtesy Light
Postby ianFRST on Sun Sep 18, 2005 12:15 pm
AW3K wrote:Have you ever had a passenger in the back that wants to look for something in a bag or they dropped something on the floor at night?
nope :lol: :P
nice guide tho :D
ianFRST
Postby Max M4X WW on Sun Sep 18, 2005 1:15 pm
Sweet :D Not sure if i can be arsed with the roof lining tho, Does the whole thing need to come down?
Your car: Mk3.5 ZT & MX-5!
Car: 1995 Ford Fiesta Azura
Postby AW3K on Sun Sep 18, 2005 1:17 pm
Max M4X WW wrote:Sweet :D Not sure if i can be arsed with the roof lining tho, Does the whole thing need to come down?
i suppose you could just take down the back, front and pasanger side, and leave the drivers side up.
AW3K
Postby Max M4X WW on Sun Sep 18, 2005 1:20 pm
Hmm, Just my dodgey glued in mk4 front light! I can take the glass out to get at the wires but dont want it looking any worse :P
Postby AW3K on Mon Sep 19, 2005 9:21 pm
Max M4X WW wrote:Hmm, Just my dodgey glued in mk4 front light! I can take the glass out to get at the wires but dont want it looking any worse :P
Do you have to glue a mk4 light in then?
AW3K
Postby Max M4X WW on Mon Sep 19, 2005 9:41 pm
I did, wouldnt fit for s**t. Had to butcher my roof and theres hardly any plastic left of the mk4 item!
Postby MAD_Adamski on Mon Sep 19, 2005 10:20 pm
the only floor i can see with this guide is that the mk3 light just works when it wants to anyway!!!!!! :lol: :lol: :lol:
so why install another to p.i.s.s you off!!! :lol: :lol:
:P
Ad
MAD_Adamski
Postby AW3K on Tue Sep 20, 2005 8:42 pm
never had much bother with the mk3 light myself.
it does its job and that what i want it to do.
:p
AW3K
Postby mk3phill on Wed Sep 21, 2005 3:46 pm
adamski frst wrote:the only floor i can see with this guide is that the mk3 light just works when it wants to anyway!!!!!! :lol: :lol: :lol:
:P
Ad
nice guide but i agree,....mine has definatly got a mind of its own. might do this one day when am bored :D
Radient red 1.1i = R.I.P K-Tay June 2006
June 2006- present 1991 Polo Coupe "Turbo"
June 2007-September 2007 Mk2 Golf Ryder - R.I.P,. my your heart live on! 1.3Turbo engine!!!
mk3phill
Postby AGAR on Sat Sep 24, 2005 12:56 pm
Another nice touch, but personally i couldn't be bothered going to all that effort for pesky rear occupants, they should consider it an honour to be in the car in the first place never mind having the luxurious advantage of a rear light. :lol: :lol: :lol:
AGAR
23:21, 29th April 2013 web
