Poly bush and lowering kit recommendation
Postby 96festy on Tue Jun 08, 2010 10:25 pm
As the title says, can anyone recommend a company that does a decent poly bush kit for a mk3.5 fiesta, 94-96?
I was talkin to the lads at rally design in santa pod at the weekend, and they only really do the rear beam bushes
and is there a place that does upgraded bottom arms for the front suspension with stiffer ball joints and bushes, mine are fairly screwed and knackered :( :(
thanks guys :D :D
Phil
http://www.everyfordireland.com//.<< A forum for all ford fans
96festy
Re: Poly bush and lowering kit recommendation
Postby fiend on Tue Jun 08, 2010 10:35 pm
fiend
Postby 96festy on Tue Jun 08, 2010 10:41 pm
oh thanks very much for the quick reply :D :D
must give powerflew a ring tomorrow then :D :D
96festy
Postby Turboboy67 on Tue Jun 08, 2010 10:43 pm
Powerflex for bushes
AVO or GAZ coilovers to lower the car
Turboboy67
Your car: 911GT3 RS
Postby 96festy on Tue Jun 08, 2010 10:50 pm
Carbonboy67 :Powerflex for bushes
see, i dont really want coil-overs for the expense of em, it is still only a 1.1, not a 2.0 RST and i only have a part time job, was lookin at lowering springs from fiesta centre??? anyone have any experiance at all?? :-? :-?
96festy
Postby fiend on Tue Jun 08, 2010 11:03 pm
If you just want springs go for Gmax or if you want to spend a little more have a look at Spax springs.
Spax do very good uprated shocks kits aswell.
fiend
Postby 96festy on Tue Jun 08, 2010 11:10 pm
fiend :If you just want springs go for Gmax or if you want to spend a little more have a look at Spax springs.
so spax or gmax, right cool, ill have a look now :D :D
96festy
Postby fiend on Tue Jun 08, 2010 11:51 pm
There is a set of Gmax ones on Ebay at the moment..
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0442631592
Never heard of this make but you might be lucky and get them for cheap..
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0442087437
fiend
Postby 96festy on Wed Jun 09, 2010 9:26 am
cheers for that, put em on watch :wink: :Q
another question, i cant remember what website i was on :o but ye no the rubber bit of the front suspension at the top of the strut tower between the strut and the tower?!?!? i found a polybush one of them...
are they any good? and who makes em????
sorry for all the questions :(
96festy
Postby fiend on Wed Jun 09, 2010 12:02 pm
Flo-Flex make them, a few people on here have used them before..
http://www.floflex.co.uk/index.php?cPath=23_56_59
There kits actually seems alot cheaper than Powerflex.
fiend
Postby jonyb4 on Mon Jun 28, 2010 1:15 am
aye flo flex aint bad, not ha enough use of mine to compare to powerflex but so far they seem good :Q
plenty of lowering springs to be found on ebay mate
Postby RS rob on Mon Jun 28, 2010 6:46 am
the cheapest i'd go for springs is the g-max kit,
had that myself years ago and it did the job well
as for bushes i'd go for powerflex and nothing else,
the other cheap companys come and go over the years
heard/read a fair share of horror stories for them aswell with gearbox bushes etc riping through
RS rob
Postby brandon mitchel on Thu Sep 30, 2010 7:39 am
Can it be used to lower a dodge challenger? Are all lowering kits the same? Thanks.
brandon mitchel
