My Fiesta Cossie
Postby jayrs on Fri Aug 24, 2007 9:38 pm
how come :-?
Postby fiecos dan on Sat Aug 25, 2007 9:51 am
Everything was put on hold whilst i was working on the cossie,
and now i've got a back log of customer's work that needs to be done 1st, as well as sort the XR2.
As well as working long hours at work.
So once i've got a clear time period, i'll get back on it.
Cossie 11.1@124 - xr2tt 13.6@100mph
fiecos dan
Postby jayrs on Sat Aug 25, 2007 10:31 am
i gota mate.
shame but i guess its what pays the bills
Re: My Fiecos and Xr2tt, 5-8-07 cossie rebuild.
Postby fiecos dan on Sun Sep 30, 2007 1:35 pm
Not done anything on cossie since last update, but heres some pic's
Cossie first.
-Rebuilt head, striped, cleaned, skimmed and lapped valves,
-Some of the parts,
-Damaged bigend and oil pump,
-Reground, (BUT STILL BENT) crank
-Modifie'd front pully for more room to move the rad back
-Hone'd block,
-Built bottom end, with new oil pump, Bent crank, rings, shells, seals, skimmed flywheel, new clutch, new balanced No4 rod.
-While i'm 'CC' checking the bottom end
- while i check the crank stoke's
- While checking the crank for bent ness
-New Rad, inter and fans.
- polished header.
-Rebuilt Dome front plated diff,
-Rebuilt rear calipers.
fiecos dan
Postby fiecos dan on Sun Sep 30, 2007 1:52 pm
But i have done abit on theXR2tt,
8-07
- i've fitted the new EMS 5 ignition setup, but had issue'd with it missing on idle, but cured this last night. So will be setting it up this week.
- Gaz coilovers are fitted on the front with 300lb springs, i had to modifie the shocks, hub's and space the wheels out 10mm to fit these, but they are on.
Did have 9" springs, but couldn't lower the car past 35mm, so i fitted 8" items on now, and i've had them as low as 65mm drop with out scrub, but have put them back to my original height of -50mm.
I tried to set the front suspension up a few weeks ago, but i had a issue with the amount of castor i'm running, and play in the top shock bush,
so i've got to modifie the bottom and top cup to fit the new castor.
9-07
Fitted the new rad, and intercooler setups.
To do so,
-i've cut some of the front panel, and cross member, and seam welded the cross member.
-new rad and inter mounts have been welded in place, all the rad plumbing needed changing.
-the number plate needed repositioning, and the bumper needed quite abit of work to fit the new inter.
-I've made all new St/St boost pipe work,
-also i've made a new Alternator heat shield, and completely heat wrapped the starter motor.
To do plans
Will set front end suspension up,
fit new spax rear socks,
New rear brake lines, 1 new front, pads and fluid,
Engine oil and filter, and gearoil,
Refit a Choke on the R5 carb, as never had one fitted, and can be a Bic™ when cold weathers here,
Sort the best rad fan i can get in there,
Full set (first since i fitted the T3)
fiecos dan
Postby jayrs on Sun Sep 30, 2007 2:11 pm
fair bit of work going on there i see mate, but why fit a bent crank? i take it that its not that bad?
Postby fiecos dan on Sun Sep 30, 2007 2:26 pm
The crank wont be getting used, i didn't know it was bent till the bottom end was built so i could measure/check it.
The machinest told me it was straightened with the grind, but after i checked it, i found out he f-cked the crank, as the stroke's are well out, and its still bent.
fiecos dan
Postby fiecos dan on Sun Sep 30, 2007 8:43 pm
Time for Xr2tt pic's.
- Escort Cosworth Rad fitment,
New intercooler,
-New pipework, awaiting abit of tig welding
-And as i'm running @ the moment, no inter.
-Alternator heat shield,
fiecos dan
Re: My Fiecos and Xr2tt, 30-9-07, full updates and pics, pg 11
Postby jayrs on Sun Sep 30, 2007 9:30 pm
bummer about the crank mate :(
Postby fiecos dan on Sat Oct 06, 2007 8:14 pm
jayrs :bummer about the crank mate :(
i know, the machinest was meant to be the top of his game, but he seriously f-cked my crank, and wasted alot of my time and money.
Pipe work finished and fitted.
fiecos dan
Postby TIL13R on Tue Oct 09, 2007 10:38 pm
Wow some very impressive work going on there! i would just be happy with the xr2tt nevermind the Cossie one aswell!
Like the piping going on tho ;) Top Work ! :D
Tiller
TIL13R
Postby fiecos dan on Sat Oct 13, 2007 11:49 am
Thanks mate.
fiecos dan
Postby Sphinx on Sat Oct 13, 2007 2:35 pm
Very thorough and professional!! Impressive! :D
Postby fiecos dan on Wed Oct 17, 2007 7:18 pm
Cheers :)
fiecos dan
Postby fiecos dan on Mon Nov 05, 2007 8:31 pm
The xr2tt had a bad day yeaterday, and N-1 rod put a hole in the front of the block.
So its time to strip and break it.
fiecos dan
Re: My Fiecos, Xr2tt being strip'd for breaking.
Postby FRSJON on Mon Nov 05, 2007 9:06 pm
sorry to hear your stripping it... :( lovely car....well thought out....proffesionally built ....its a credit to you....as your breaking it ,id be intrested in the rs1600i rocker cover at the right price... :)
FRSJON
Postby Smo on Tue Nov 06, 2007 10:46 am
fiecos dan :The xr2tt had a bad day yeaterday, and N-1 rod put a hole in the front of the block.
Ah what :( I passed your XR2 on Sunday afternoon too! I would have tooted, but you wouldn't of had a clue who I was :lol:
What actually happened? Rod bend/snap? Bolt snap? Surely you can build up another bottom end using a decent 1.6 CVH block - from what I've gathered on here, you seem pretty capable!
Smo
Postby HCS PIMP on Tue Nov 06, 2007 5:13 pm
why not but an zvh 1.6 turbo come on it silly to give up on a little beauty and i absolutly love ur cossy fiesta and i wanna match it or buy it one day i absolutly hadte bad engineers who dodge doing engine grinds my si head got skimmed and not prsssure teset anywho it seized fully this tiem the beras gone but it soul will pass on to the new si im gonna get
HCS PIMP
Postby fiecos dan on Tue Nov 06, 2007 7:46 pm
Cheers lad's for the comments,
i'm not putting up forsale yet, as not 100% certain, as there's a part in me that just wants to finish. So gonna give it at least a week to think it thro.
I've not touch'd it since i towed it back to my house, so as yet dont know whats let go or why.
i could easierly rebuild it as have enough parts around to rebuild it, just time is the issue,
50 - 65 hours @ work, then 15 - 40 hours on other stuff, dont leave time to do my own stuff, and if i cut my work hours, the bills wont get paid.
fiecos dan
Re: My Fiecos, pondering about the Xr2tt's future
Postby jayrs on Tue Nov 06, 2007 9:57 pm
finish it :D
Postby Luke2008 on Tue May 26, 2009 1:23 pm
Lovely car mate, would be a shame not to get it back on the road, just read through this thread and I love it, the cooler on the Cossie is probably the biggest I have seen. Love the XR2 as well.
Luke.
No, My Bonnet Isn't Open!
Luke2008
Postby dangerousdave on Thu Jun 25, 2009 1:02 pm
are you still aroud dan?? i just sat here and read the whole thread to find it stops at the best bit!!! :o :o :lol: What happend??? lol
dangerousdave
Postby fiecos dan on Thu Jul 09, 2009 9:29 pm
Cheers lads.
Yeah i'm still around, but niether cars have not been given much attention, or been on the road. I did have a spell a month or so ago where i done some work on the cossie,
The front Avo's have been respeced and rebuilt, Pipers re polished the cams,
modified the header tank, steering joint, measure up for and got some adjustable top mounts.
My time has been shared to work, DIY and my R6 motorbike and trackdays on that.
fiecos dan
Postby Ruishy1 on Fri Jul 10, 2009 7:50 am
HCS PIMP :why not but an zvh 1.6 turbo
there is absolutely zero point in doing that.
bad luck on the machine work and the blown engine mate, but always give you the chance to re-spec and upgrade :D
Ruishy1
Postby fiecos dan on Sat Jul 18, 2009 5:41 pm
Cheers.
I've finally made up my mind, The xr2tt is now being broken for parts.
Here's a link for my forsales.
http://xrtwo.speedcentral.co.uk/viewtop ... highlight=
fiecos dan
Re: My Fiesta Cossie
Postby soundboy93 on Sun Oct 10, 2010 1:04 pm
i know the last comment in this thread was last year, but I saw your car in your sig mate, awesome stuff! and a proper inspiration!
soundboy93
Postby fiecos dan on Sun Oct 10, 2010 5:01 pm
Cheers mate.
The Xr2tt is no more, the shell and 80% of the parts have been sold.
No real updates on the cossie. Its still sitting on axle stands. But
I've had the front shocks rebuilt for track by Avo,
The cams went back to Piper to make sure they are the correct profile, and a polish.
I've modified the header tank,
I remade the steering UJ.
fiecos dan
Postby fiestajames on Wed Oct 13, 2010 3:31 pm
both your fiestas are and were mint mate ...
can i just ask what carb set up your using on the xr2
regards james
fiestajames
Your car: xr2i
Postby fiecos dan on Wed Oct 13, 2010 5:45 pm
Cheers mate,
I've used a 5 different carbs in my development of the xr2tt, (i used to build, spec and tune TT's)
The last carb setup i used, was a modified Reno 5 carb, which i do have for sale, complete on manifold, cables and hose work.
See my forsale post if your intrested.
fiecos dan
Postby fiestajames on Thu Oct 14, 2010 2:18 pm
fiecos dan :Cheers mate,
thanks mate ill have a look
fiestajames
Your car: xr2i
Postby Smo on Thu Oct 14, 2010 6:16 pm
Will be good to see this going again! Been a while now, hasn't it? :)
Smo
Postby TIL13R on Thu Apr 26, 2012 8:22 am
I need one of these sumps...!!!
TIL13R
Previous
