Mk3 fiesta stalks wiring diagram
3 posts • Page 1 of 1
Need the wiring diagram for mk3 fiesta stalks as I'm trying to put mk4 escort stalks in and need to know what pins do what... Then I need mk4 escort wiring diagram if anyone has one?
- K27GAR
- Your car: fiesta 1.8 16v
Re: Mk3 fiesta stalks wiring diagram
Here's the MK3:
71 is the horn
49 is ignition feed in
31 is ground
R and L are the outputs for the indicators
30 is power in
58 is illumination feed (the switch for illumination on by the lights)
54 is yet another ignition feed in (same source as 49)
55 goes to the dim/dip relay E (I think it says 55 anyway)
56B is dim/dip (goes to the relay for dim/dip to activate it)
56A is high beam (same as dim/dip to the relay for high beam)
W goes directly to the washer pump
53A is the rear wiper
53C goes again to the washer pump
53-B goes to the front wiper motor
53-2 goes to the wiper delay relay
B1 to the wiper delay relay again
B2 and again, wiper delay relay
53 front wiper motor
54 this goes to a junction just after fuse 16
71 is the horn
31 is ground
30 is power in
- DanFraser
Thank you! Just the mk4 escort one to find and match upto now!
- K27GAR
