Megasquirt on 2.1 Zetec Turbo Engine
Postby Schlupski on Tue Sep 07, 2010 5:17 am
Hi,
i hope anybody can help me.
Sorry for my bad english.
I´ve got an 2.1l zetec Turbo Engine
GT3076R Turbo
Siemens Dekka 630ccm3 injectors
Edis wasted spark
Megasquirt MSII V3.0
My Problem is that the Engine has no Idle.in the warumup enrichment the car runs with 1200rpm.when the engine is warmed up then died the engine and i have no idle.
Can anybody help me with msq?or can check my msq.
Schlupski
Re: Megasquirt on 2.1 Zetec Turbo Engine
Postby percybigun on Wed Sep 08, 2010 7:15 pm
First i'd check/change the idle air control valve.
And the throttle position sensor.
What happens if you adjust the idle screw on the throttle body?
Are you 100% sure its mapped/tuned properly?
Mk1 mondeo zetec supercharged (M45 @ 10psi, stage 2 cams, nitrous, WMI, 4-branch, koni's, polybushed/rose-jointed, 320mm brakes)
Mk1 mondeo zetec turbo (Hybrid T28 @ 19psi, FMIC, ported head, Megasquirt, LSD, koni's, polybushed/rose-jointed, Brembo's)
percybigun
Postby Schlupski on Sun Sep 12, 2010 8:44 am
Hi percybigun,
thanks for your answer. :x oh i must check the idle valve.My Engine has an 2 wiring std. fiesta turbo idle Valve.The Settings are PWM Warmup.
My Tps is correct adjust,0% - when ick kick fuel pedal i ve got 100%.
I check at this morning the idle valve,it works 100%
here is my current msq file.
thanks for your help
yipppie.zip
(6.44 KB) Downloaded 263 times
Schlupski
