help needed
help needed
Postby onslack on Wed Sep 12, 2007 6:35 pm
right this is doing my head in now
since day one of my 2.0 conversion my car's rev's hunt. i was told to replace the plugs and leads.
i replaced the plugs and leads for standard ford ones, i think replaced my iscv with a fairly clean second hand one, i also replaced the tps while i as there
the other day my car would run,but as soon as the rev's dropped it would cut out,i replaced the lambda sensor and the car started idling oki replaced the maf while i was at it
i then disconnected the water temp sensor that sends signals to the ecu and the car idles ok and the rev's stopped hunting
i replaced the water temp sensor(new one) today and the car still does it Confused , when i disconnect it ,it seems to idle ok but smells very rich
the battery has been off since 10.30am this morning and was reconnected at 5.30pm, so the ecu was reset
i dont know what else to try or to check
i couldn't feel any vacum leaks, a few weeks ago the breather hose under the coil pack was replaced
but it does sound like a "tuff tuff" noise coming from the engine when i switch it off, but not a clue where its coming from as it only me, and i can hear it when i am by the drivers seat
onslack
Sponsored Links
(not a real person)
Re: help needed
Postby Tweek on Thu Sep 13, 2007 6:32 pm
Any air leaks on the inlet manifold?
Car: 1994 Ford Fiesta Ghia 16v
Re: help needed
Postby onslack on Thu Sep 13, 2007 8:00 pm
i have had a feel around the inlet and i cant feel any, but i swear i could hear a sound that sounded like i had a leak
i was told to spray wd40 to look for leak
i thought air leaks make the car rev's high tho, mine just hunts :-?
onslack
Re: help needed
Postby Tweek on Thu Sep 13, 2007 10:53 pm
My inlet's leaking and it's idling a bit dodgily at the moment. Goes low then comes back up for a bit, then drops down again lol.
Re: help needed
Postby onslack on Fri Sep 14, 2007 1:46 pm
yeah thats what mine does, but it only seems to do it when it hot or warmed up :-?
onslack
