Guide to fitting a boot release
Postby heeman10 on Thu May 22, 2003 10:25 am
Electrical connections:
1. Permanent live to one big spade connector on switch.
2. Run wire from other big spade down car to contact plate (perhaps second in from the right, but can't remember...depends which contact pin you hook the release up to)
3. Two wires on the release itself. Brown goes to earth, live connects via bullet connector on to the inside of one of the contact pins. (Now you know which contact plate to hook the switch up to - just match it with the pin above)
4. There are two small spades on the back of the switch too - these control illumination. If you find a wire which is live with the headlights on, tap into that and connect to one small spade, and earth the other small spade. Now the switch will light up green with the lights like mine! :D
Physical Fitting:
The plastic interior trim on the inside of the tailgate must be removed to get to the relevant panel. There are two holes, vertically aligned perhaps 6cms apart. The holes in the boot release match up to these when it's positioned on the inside face behind the holes.
The boot release works by pulling up on the latch mechanism, and so the latch needs taking out to connect the rod. This is done by undoing the two torx head bolts on the latch plate. There will already be one rod in place - the standard boot lock rod. It slots into a little white plastic clip which retains it inside the latch. There should already be a second white plastic clip in place for the boot release rod. I think I connected the latch-end of the boot release rod first, then held the latch back in place and clipped the solenoid end of the rod in place, tightening the latch back in place afterwards.
This should now be the job done! Replace the plastic interior trim and the job should be finished off. Test..and smile :D
Location: Somerset, Drives: 400Nm 8P2 Audi A3 2.0 TDI Sport
Sponsored Links
(not a real person)
Postby PhatFesZs on Thu May 22, 2003 10:59 am
cheers m8,i`ve just saved it to and pasted that to word pad on my pc gonna use this when i get around to fitting my boot release kit!
cheers chap! :)
"R.I.P Elm_Us 2004"
PhatFesZs
Postby Huggie on Thu May 22, 2003 1:38 pm
:) Well done, Mate glad to see someone writing guides, could do with some moe, I would but i don't want to be held responsible if you lot muck up
:lol: :lol: :lol:
Huggie
Location: Drives: People Mad oh...and a Multi Coloured Fezzy
Postby PhatFesZs on Thu May 22, 2003 2:44 pm
or maybe it`s time for a "guide" section on the forum maybe.....?
anyone :)
"R.I.P Elm_Us 2004"
PhatFesZs
Postby heeman10 on Thu May 22, 2003 5:50 pm
Maybe...it's too easy for people not to notice things, or search for previously posted topics. A guide forum wouldn't be a bad idea at all!!
Postby heeman10 on Sun May 25, 2003 12:36 pm
BTTT for Al :p
Postby 8skellerns on Sun May 25, 2003 7:43 pm
How would the circuit work though if it was to work like it was factory fitted? I.E It only works with the ignition off so you dont accidentaly pop the boot on the motorway :o And it holds the popper on for a couple of seconds after pushing the switch like it does on cars fitted with it as standard?
Drives: MK2 Fiesta 1.4 Ghia (1988) Focus 2.0 Zetec (2003)
8skellerns
Postby LeeB on Mon May 26, 2003 9:06 am
The problem with the standard ford boot release is the fact that it can be popped if someone smashes the window and presses the button.I've got mine wired to an ignition live,think I'd rather take my chances on the motorway :wink:
Lee
LeeB
Postby RS_Rawli on Wed Jun 11, 2003 7:33 am
wire it to an auxillary live like on the rest of the fords then :rolleyes:
RS_Rawli
Postby Tomdom on Thu Jun 12, 2003 10:28 pm
thnkx mate this proved very helpfull today :D
ImageBreaking 2i, lots of parts available!, pm me
Tomdom
Postby Unplugged on Sat Jun 14, 2003 2:00 am
Gunna have a look down the scrapper on monday for a Boot Motor and Maybe Central Locking motors as well :) if I can chave them then I mihgt make a manual switch in the car for boot release
If I steal the switch and contact plate/pins from another car any idea if the cabling is already run down tho9ugh the body?
Unplugged
Postby Project on Sat Jun 14, 2003 2:46 am
No - the boot release wiring is part of the electric pack loom, which is easily unplugged from the rest of the car if you lift the right-hand sill trim and cut the zip ties holding it to the bottom of the dash :)
Project
fiftyoneCL
fiftyoneCL
Postby Unplugged on Sun Jun 15, 2003 1:18 am
So if I skank the contact plate / pin.... The Loom from a car with Rear Wipe / Boot Motor and Coutesy light it should plug in under the dash and mean I shouldent have *too* much trouble when stealing the coutasy light andboot release motor :) I know I willhave to find somewhere to put the boot release but I might makea panel to place the button next to the rear heated window switch
I might even just run an extra cable down depends on how much work its going to involve ;)
Unplugged
Postby heeman10 on Thu Jun 26, 2003 8:37 pm
I'd just like to remind ppl that if they carry out this modification to their car following my guide, they own me £15 in royalties :p
Postby Ian C70T5 on Mon Jul 07, 2003 6:05 pm
Whats the difference of the soloniod from the Mk4 and the mk3
Ian C70T5
Das Ist Kapput
Das Ist Kapput
Postby thesylph005 on Sun Jul 13, 2003 2:37 pm
ive just fitted a boot release and i did it slightly differantly.
when it came to wiring up to the power, looking in the haynes manual, the boot release was wired up to the ignition relay. this relay had 5 spades on it, the one in the centre of the relay being labled 37a
however in my fuse box the ignition relay had only 4 spade and was missing the one in the middle. to get an idea of the raly you need, look at the lighting relay wich is on the opposite side of the board (mine is blue and has a diagram on the side)
what you want to do is get anothe relay like the lighting one, or the ignition with the extra middle spade.
(there is a space for the middle spade in the relay spot)
now, rather than struggling to insert a wire properly from the underside of the fuse box, what i did was strip a wire and wrap it round the middle spade and then thinly recoat the wire with some duck tape being sure that no wire could make a connection between other spades.
now reinsert the new relay into the place for the ignition relayu and voila
(remember to dissconect the power before you do this)
now the b/r will work wen the key is not turned or turned once. once ignition is activated, it will cease to function.
thesylph005
Postby csmith on Thu Jul 24, 2003 11:06 am
even if it does release pn the mototrway its not as if it pops striaght up just unlatches simply pull over and fxix it, mine did it several times @ 80mph cause of dampness in thed switch it would make more sense to wire it so it ONLY works when the ignition is on as to me motorays aint a problem but getting your car broken into and boot looted is,
csmith
Postby 8skellerns on Fri Aug 15, 2003 9:56 pm
I had a little investigation on a fiesta zetec-s at work today and found that whenever the doors are locked or the alarm is activated, the boot release switch doesnt work. I had to sit in the car and activate the alarm / lock the doors to try this out. :)
8skellerns
Postby whitey on Thu Dec 04, 2003 12:30 am
not trying to sound too dumb... or like an opportunist... but if i was gonny nick something from a car... wud i really be bothered if the boot popped or not? i mean if ive broken a window i can open a door... and dont all rear seats fall forwards? jus about anything that can get in the boot thru the hatch can come out thru doors? if not... ure not likely to run off down the road after stealin it without being noticed!
So i wud say... if u hav the wiring - do it normally... if not do as u fcuking please! lol
Merry Xmas!
Whiteee
FOR SALE: FRST Bonnet with vents - Four Spoke S1 RS Steering Wheel
whitey
Postby Percy! on Tue Dec 30, 2003 1:45 pm
This may sound dumb but I can't get the interior trim off the boot, I have removed all the screws and it still won't move! :cry:
What am I doing wrong? or what else needs to be done?
Percy!
Postby Superal on Thu Jan 08, 2004 3:53 pm
i know what you mean percy...its a b*tch to get off...gave up in the end :lol: until next time :)
Superal
Postby Superal on Wed Jan 28, 2004 11:43 pm
anyone know which connector is the standard one for the boot release?
Superal
Postby heeman10 on Wed Jan 28, 2004 11:46 pm
Can't remember...doesn't matter, as long as everything connects up on both sides of the same pin/contact plate it'll work :)
Postby Superal on Wed Jan 28, 2004 11:49 pm
this weekend is probably gonna be boot release fitting time so if i get stuck i know who to contact :lol:
Superal
Postby heeman10 on Wed Jan 28, 2004 11:53 pm
lol I'll pm you my number just in case :)
Postby Superal on Thu Jan 29, 2004 12:10 am
this thread needs pictures and funky diagrams :bonkers: :lol:
Superal
Postby dj_mase69 on Sun Mar 14, 2004 10:51 am
yea right. iv gotta try and sort it out soon so pics and "funky" diagrams would be spot on!
dj_mase69
Postby heeman10 on Sun Mar 14, 2004 10:53 pm
Unfortunately it's almost a year since I wrote this, which means my boot release is quite at home in my tailgate now, so I won't be taking it all apart for pictures!!
Postby Superal on Mon Mar 15, 2004 12:27 am
heeman10 wrote:Unfortunately it's almost a year since I wrote this, which means my boot release is quite at home in my tailgate now, so I won't be taking it all apart for pictures!!
booo :lol:
the boot release isn't the problem it's the wiring..i'd probably end up blowing something up :lol:
luckily a fellow forum member said he'd lend me a hand :)
Superal
Postby dj_mase69 on Thu Mar 25, 2004 1:25 pm
Superal wrote:this thread needs pictures and funky diagrams :bonkers: :lol:
i fitted my boot release 2day but ill dis connect it all and get some pictures and diagrams up for you'll.
give me couple of days tho :)
dj_mase69
Postby Superal on Fri Mar 26, 2004 1:13 pm
nice...i bought a de-locked/de-wipered tailgate with the boot release already on so i just need to get it wired up now...
Superal
Postby Syorme on Sat Mar 27, 2004 1:06 am
if anybody dose have any pic would be helpful
just brought a boot release so trying to fit it
Syorme
Postby wywywywy on Sun Mar 28, 2004 10:22 pm
dj_mase69 wrote:i fitted my boot release 2day but ill dis connect it all and get some pictures and diagrams up for you'll.
Any pics yet? :p
wywywywy
Postby bluefiestamk3 on Mon Mar 29, 2004 12:30 am
Its not exactly difficult from what i remember, i jus sold syorme a boot popper.
Right you have (coming from the motor) 1 red and white wire and one brown i think? thats the earth wire, the earth wire should have a ring terminal on it (syorme i think the one is missing off the one i sold you) and then the bolt screws into the boot, there should be a hole.
Red and white wire needs to go on the contact pin plate in the tailgate, cant remember which prong it goes on (will look tommorow)
Then in the shell of the car on the contact plate there will be a wire in there, again i cant remember which prong i will look tommorow.
The wire from the contact plate goes all the way to the front of the car, hide is under the boot carpet down the sides of the rear seats then under the sill covers or something, then it goes onto the switch for the boot release.
There will be 2 prong/pins on the boot release switch, one of them you wire the wire from the boot to, the other one, you take a length of wire attach it to the battery ,remove the header tank (no need to remove hoses or drain water) just one ten mm bolt and it lifts up, behind there in the corner will be a round rubber thing, it will lift up, insert this wire down there (IF YOU HAVE CONNECTED IT TO THE BATTERY MAKE SURE THERE ARE NO BARE WIRES ON THE OTHER END BECAUSE IF IT HITS THE METAL OF THE CAR SOMETHING MAY FUSE OUT) when you have pushed the wire down that ruber grommet hole it will appear ni the footwell by the accelerator pedal, all you do now is run it to the switch and put it on the other prong, boot release should now work.
tommorow i will get pictures and paint diagrams of things to go with this.
I also have all the connectors prongs and some wiring and switches for this first come first served though only got one, got a couple of xr2o style boot release switches.
YOU WILL NEED TO GET THE CONTACT PLATE AND CONTACT PIN PLATES FROM A XR2I OR RS TURBO OR ANYTHING WITH A BOOT POPPER AS STANDARD!
As i say, pics tommorow for ease of understanding! promise, be about 2pm
bluefiestamk3
BANNED MEMBER
Postby Syorme on Mon Mar 29, 2004 12:22 pm
oh great is that wire important to have.
Syorme
23:21, 29th April 2013 web
