295mm discs
295mm discs
Postby bas saph on Thu Apr 28, 2011 7:05 pm
hi does anyone use or know if 295mm disc will fit in the fiesta's :-?
bas saph
Sponsored Links
(not a real person)
Re: 295mm discs
Postby crazycage on Fri Apr 29, 2011 9:42 am
bas saph wrote:hi does anyone use or know if 295mm disc will fit in the fiesta's :-?
on what wheel ,i have fitted 310mm under 15" comps and 330mm under 17" comps :)
crazycage
Re: 295mm discs
Postby bas saph on Fri Apr 29, 2011 6:29 pm
Thats cool just wanted to know if posible as have some to sell mayby. I think In have puma raceing pads, disc, and calipiers :-?
bas saph
Re: 295mm discs
Postby Pumatt on Mon May 09, 2011 12:09 pm
Dont think the racing puma front brakes will fit under 15" alloys, unless you have (like above) the luck of fitting them. With the Alcon racing puma brakes, have a look into them, their expensive to buy, expensive pads and discs and the callipers need reconditioning from time to time.
Oh, and as for fitting them, they should be simple as same hubs as the puma :)
Id recommend 278mm brakes from the mondeo st24 around £40 for the set up.
Or if you have a little more money 300mm from the focus st170 brakes.
Ford Escort GTi
Ford Puma 1.7 ..... in bits for scrap.
Pumatt
Re: 295mm discs
Postby bas saph on Mon May 09, 2011 12:21 pm
Pumatt wrote:Dont think the racing puma front brakes will fit under 15" alloys, unless you have (like above) the luck of fitting them. With the Alcon racing puma brakes, have a look into them, their expensive to buy, expensive pads and discs and the callipers need reconditioning from time to time.
cheers for that i have some in the for sale section. I started this thread to see if it was worth listing them. THANKS THOUGH. if they dont sell Im goingto fit on my saph :wink:
bas saph
23:21, 29th April 2013 web
