2.0Ltr Parts
2.0Ltr Parts
Postby onslack on Mon Jun 12, 2006 8:21 am
Right i am starting to buy some more parts for my 2.0Ltr conversion
just want to make sure i have the right bits noted down before i buy anything look
*Cambelt - ( 2.0Ltr Item)
*Tensioners - ( 2.0Ltr Item)
*Water Pump - ( Fiesta 1.6/1.8 Pump)
*Oil Pump - ( Fiesta 1.6/1.8 Pump)
*Oil Filter ( for Festa oil Pump)
*Fuel Filter
*HT Leads - ( 2.0Ltr Item)
*Aux Drive Belt - ( 2.0Ltr Item)
Alternator - (Fiesta 1.6/1.8 Item)
*Spark Plugs - ( 2.0Ltr Item)
how does all that lot sound , if have forgotten anythig please add it
Terry
onslack
Sponsored Links
(not a real person)
Postby adamburzynski on Mon Jun 12, 2006 8:50 am
u want the 1.6/1.8 aux drive belt. there are 2 versions, with and without power steering...
adamburzynski
Postby onslack on Mon Jun 12, 2006 8:55 am
cheers for the reply mate
i will need the aux drive belt with power steering
does everything else look ok?
onslack
Postby jdfiesta on Mon Jun 12, 2006 9:50 am
oil pump isnt a necessity, you can use the shorter cvh oil filter instead
JJ
Image[/url]Image
www.volvot5.co.uk
Four cylinders?! - is that it?
1999 V70 T5 SE - 2.3, 5 cylinder, 20V, VVT, Turbo, 250bhp, cream leather, climate control, the works!
jdfiesta
Postby Ollybee on Mon Jun 12, 2006 5:09 pm
jdfiesta wrote:oil pump isnt a necessity, you can use the shorter cvh oil filter instead
JJ
Do this, it's a lot fricking easier!
YRN Thread - yrn-vt151433/
Ollybee
Location: Ilkley, West Yorkshire. Drives: YRN & Focus Titanium TDCi.
Car: 1996 Ford Fiesta Quartz
Postby lucasdemoley on Mon Jun 12, 2006 5:13 pm
Which cvh one should I get?
lucasdemoley
Postby Ollybee on Mon Jun 12, 2006 5:22 pm
Think they are all the same, but it's the one with same diameter as a zetec filter but is half the length. :bonkers:
Ollybee
Postby adamburzynski on Mon Jun 12, 2006 6:26 pm
y is it easier cus its not as long? u saying use the zetec oil pump with the cvh filter, yeah?
adamburzynski
Postby Ollybee on Mon Jun 12, 2006 6:30 pm
Exactly and it's easier as you don't have to swop the 2 litre oil pump to a 1.6/1.8 version.
The fiesta one has a straighter design so as to not foul the inner wing. The mondeo type has a bend towards the inner wing so with the zetec filter on it, it is damn close. The engine will go in but when it's running the engine movement on the mountings starts knocking a hole in the oil filter, then you have problems.
The cvh oil filter is the same diameter as the zetec but just shorter so you can keep the mondeo oil pump and the shorter length of filter avoids the inner wing.
Ollybee
Postby onslack on Sun Jun 18, 2006 8:36 am
cheers for all te replies guys
all my parts have now been ordered 8)
onslack
Postby G6Griff on Sun Jun 18, 2006 10:54 am
yeah ive got the cvh filter on mine and it fits in no problem at all!
G6Griff
